Engine dimensions?
Koray
Anyone know the dimensions of a gen 2 motor? Im going to be building a cross kart with a hayabusa engine and wanna make sure ill have enough room to fit the engine. Thanks.
as far as i know - nowhere mentioned
so get an engine and do your own measuring ;-)
if you, at the end, are very helpful for all others make a schematic drawing / sketch (by hand) with all the taken values and post it here
then I, for example ;) , could take this sketch and make a CAD drawing of it for my homepage where then everyone could find it.
I ended up finding a CAD model that is supposedly accurate within 1/4 of an inch designed to be used for exactly what i'm doing. So I used that instead. Ill post the link here incase anyone else needs it. dp vehicle links
I believe this is of a gen 1 motor though, does anyone know if there is any size difference between the gen 1 and gen 2?
