tpallanki
Ran into problems with Power Commander III USB. I wonder if anybody else ran into similar problems and how to fix it.
Here is the story:
Changed the Piston kit in the engine. Added JE 1307 Piston kit. With the PC (Zero map) connected the engine did not start. Disconnected the PC, than engine started fine and ran fine as well. Reconnected the PC, engine ran fine. Tried a few maps. One of the maps worked fine, so left it loaded. Engine ran fine. Next day, in the morning engine did not start. Disconnected the PC engine started fine and ran fine too. Tried to reconnect the PC, but anytime reconnected the engine has problems this point on. It takes a long time for the engine to start up and it does not stay on. When it runs, it does not run right. The engine would not run on high rpms at all.
Tried to reconnect the PC several times, same happens over and over again.
Anybody had similar issues? Any idea how to fix it?
Here is the story:
