Fireman6615
Rode to the mountains today with no problem. First set of twisties the bike cuts off, I thought I may have bumped the kill switch but it was still on. After a couple of seconds it came back to life so I kept going and it did it again, only this time I looked at the gauges and they were dead, then "Check" was in the panel and the FI light was blinking and she came back to life again. So I stopped, turned it off and gave her a once over. Nothing out of the ordinary. Thought maybe the side stand switch, the tab that pushes against the sensor seemed a little bent so I straightened so it would push the sensor rod a little better. Fired her up, no FI light and all seemed well Rode on and went through the twisties at varying RPM for about 20 minutes and all seemed well. Then it did it again. Came home and I thought about the side stand switch more, so as I was riding I eased it down and duplicated the same problem. Engine dies, Check flashes, FI light blinks. Once I got home I put it in dealer mode and checked for codes, nothing there other that the throttle position sensor is at the bottom, I'll fix that too. So does this sound like a failing side stand switch? Does the Tip Over sensor and the Clutch switch duplicate these same problems? Thought it may be one of the sensors, any ideas would be great. Thanks as always.
