Connecting Motion Pro Sync Pro Carb Tuner
#1
How should someone connect a Motion Pro Sync Pro Carb Tuner to a Busa equipped with a turbo setup? I'd either need to disconnect the four lines that go to the MAP/IAP Sensor or add four Tee fittings in the lines. Thanks.
Wag
Evil Demon Busa Rider
No, just disconnect all four lines, and replace with the lines to the tuner. I connect #1 to the left-most throttle body, etc.
There are pictures here on the board in various places which will show you how to hook it up.
EDIT: Here ya go. https://www.hayabusa.org/forum/maintenance-do-yourself/28870-synch-throttle-bodies-03-busa.html
Also, as I recall, Icemann had a great set of photos. So did Jinkster but his connection technique was a little different. Just as good though.
--Wag--
#5
if you disconnect the iap sensor it will run horrid trying to get it to idle would be a chore in itself
so you are telling me you synced you TB's with the iap disconnected and had no issues with syncing it?
#7
Interesting... whenever I get around to doing this, and that may be a while, I'll sync with the IAP disconnected, then check it again using Tee's and the IAP connected. I'll post here what I think.
I also noticed the comment on using vacuum gauges to sync the throttle bodies. Personally that sounds better to me than using anything with mercury. I assume the end result would be the same so are there any particular vacuum gauges I should use?
smithabusa
Site Sponsor
on my wife's 05 anyhow, it runs like crap if the vac line is pulled from the sensor, but if you unplug the sensor electrically it puts it in limp mode and it idles quite well.
Mr Bogus
Trouble Makers Inc.
gauges are hit and miss.. .if you can calibrate them, that is a lot better... gravity, liquid and vacuum are much more accurate for "balancing"..
However if you hook all the gauges together, sync them first, then do the TB's, you can do a pretty good job.. (did a 6 pack rig like this so I could sync the carbs on a V12 Jag).. PITA...
they make a unit that does not use mercury.. find it, buy it, be done with it..
Similar threads
Most likes - Past 7 days
Latest Bikes
Forum statistics
Threads
171,249
Members
47,031
Latest member
thomas malley
