just buy the MPS kit. why wud u want to fuk around trying to make ur own wen u can buy one ready to use.
I wud look into buying a Cycletec kill box tho cause any other kill box is gonna set off ur F1 light every time u shift which becomes very annoying or u cud cover the F1 light with tape but I thought that was kinda cheesy. but the MPS one will work just fine.
i wud buy Corolina regulators tho.
Why not just get electric only light mine turns on is my win light @ end track.
Your going get tired of pumping air every time.
Seems over designed and expensive.
lol it wasn't a link it was just MPS kit. wat exactly do you think goes inside the MPS Air bottle? air?Pretty funny what your link goes to!
The MPS kits appear to be air, not C02 so it's really just an expensive way to buy some parts.
yea Matt no longer makes the kits. I did buy a new kill box from him a few months ago wen he decided to make a batch of em. I bought it as a spare in case I build another bike which is highly unlikely in this lifetime....Cycletek quit making them. That's what I was originally going to buy
an AIR system is wen u have an air compressor that fills a very small tank either placed under ur seat or if u have a swingarm that allows u to pressurize it and it recharges itself wen the pressure gets low. its not accurate and the pressures are usually too low and you can't run ur air shifter and ur waste gate off it if u have a turbo.
the MPS system is a CO2 system or nitrous if u want....
If you use ECU kill you don't need a switch kit, depending on how you want to set it up. If you want to use the GPS trigger you'll need a harness. If you want to use a mode select button you need a couple pieces of wire and a wire connector. I run the mode select method because it is more reliable.Thanks everyone for the feed back. Sorry it took so long to get back on here. We've been without power for a day and a half.
The dynotune kit looked like a better deal for sure. I'd would just have to get mps switch kit? And a 9oz. Bottle and ram bracket.
lol yea I don't know why it turned into a ricer link but I'm sure the import car was kinda funny... I've never used N20 personally but I know others who have and yes the regulator is different ur right. I hav a local Fab shop about 10 minutes from me and they have Co2 so it just easy.I've run them all, so no need for the explanation. The MPS website says you can upgrade to a high pressure system but I don't see a regulator in the pics or on their site. Their kits are low pressure air, not CO2 as the OP was asking for.
It's not good to run nitrous though regulators not specifically designed for nitrous, and nitrous regulators aren't good at regulating to 150 psi.
The "MPS kits" in your posts generates a link on my computer that directs to ground effect kits for import cars. I thought that was humorous.
