CO Test Problem
ssgunny
I am posting this for a member of another board. I have been told that he has a bone stock American specs 2006 Busa. He is stationed in Japan and is undergoing emissions testing. It was tested in Japan and the CO level was a little to high (see below). During his idle test his CO level was within standard. The test was done in Tokyo and the kpa was at 99.9 which is very close to sea level.
Below are my test results/then the Japanese standard.CO: 22.23 / 20 (Fail)HC: 1.628 / 2.93 (PASS)NOx: 0.115 / 0.51 (PASS)
Do think leaning it out some via a PC or reflashing the ECU would help?
mike1180
Banned
Take it back to the factory.
It is right there. :laugh:
I don't know what a guy would adjust to fix CO emissions. ???
Commuta_Busa
higher co levels indicates an over rich A/F ratio. If it's close to passing then do as mentioned, pull the air filter. Sounds like a little fuel triming is needed.
ssgunny
Now that is funny.
Thanks for the replies all. Makes sense about the air filter and leaning it out. How do you think it is best to lean it out? Am I on the right track by suggesting a PC or reflashing the ECU? This guy has to get the bike from Misawa to Tokyo each time for the test and that journey is not cheap so I hope he can pass the test sooner rather than later.
ssgunny
I have another question concerning this problem. This is a 20 minute test at a moderate RPM level the guy failed down in Tokyo. I could see if the filter was dirty that more fuel would be used. What if the air filter was completely removed just for the test? Or the small airbox mod done. Both mean more air but would the bike learn during the 20 minute test to adjust fuel due to more air?
Thanks in advance to any replies.
Mr Bogus
Trouble Makers Inc.
never had much luck pulling air filters on "FUEL INJECTED" motors... (well unless the thing was just plugged solid) Also, is this a "cruise" test? Idle test? or something like the old IM240 test where it is road tested on a dyno for all condition?
CO measures burned fuel in the gas, HC is unburned fuel, NoX is a by product of high combustion temps
The motor is just rich.. (20? or is it 2.0/.20? 20 is off the chart, 2% is more likely) not sure what the tipping point is on these motors but as that number goes down, the Nox is going to start rising and at some point and you go "over lean" the HC's will start to climb after falling initially..
The 02 sensor on the Gen2 takes care of all this at anything less than full throttle..
vacuum line to MAP bad or leaking *(or bad sensor, but not likely, they are pretty reliable)
leaky injectors or excessive fuel pressure
improper mapping (most likely cause IMO)
excessively nasty oil in the crank case
Charcoal canister malfunction (saturated)
low idle speed
Sometimes you can just create a vacuum leak (after the throttle bodies) and that will lean a motor enough to get them to pass (you need a gas analyzer for this little trick)
ssgunny
Thanks Bogus. I guess the problem looks more complex then just leaning it out. The owner says the bike is totally stock. Since this is the case I guess dirty oil or something faulty could be the problem. From what I understand this was two part test. The idle test was passed but this 20 minute test is what failed.
I have attached the pdf of the failed test. I had it translated so it may have some minor errors. I am not sure at what RPM range the bike ran at during the test.
Mr Bogus
Trouble Makers Inc.
actually all it appears to need is a bit of "leaning"..
Now I may be reading this wrong but it appears this is a Gen2 bike and it was only tested at idle.. I do see the 20 minute run.. curious... does a person run the throttle? (this could contribute to a "fail" and sometimes just retesting results in a "pass")
The idle speed was right at 1100 rpm so that is at the bottom of the scale.. He needs a shop at this point with a gas analyzer and make a couple small tweaks
Calibrate the TPS
Idle speed (raise a bit)
watch the CO/HC's you want the CO to go down of course but only as long as the HC's go down with it.. I am guessing this bike should have a catalytic converter so NOX and HC should never go up.. (they are consumed in the cat)
IF i was doing this (and cheating) bump the idle, back down the TPS and if need be, take the line where all 4 intake ports are married and create a small air leak :whistle: (enough to raise the idle about 100rpm)...
This really is tough work for a DIY guy and my guess is that there should be a list of shops that the emission testers should have to get work done at....
I suppose it is possible to plug a PC in and just have a leaner idle setting built right in.. flashing the ECU really would be the ideal fix provided Idle and TPS adjustments do not fix it..
ssgunny
This is a 2006 model. There is something about 50km/h at the bottom of the first page so that is what they may have ran the bike to get the readings. I am not sure of what gear it was in.
Thanks for your thoughts. Until this guy finds out the true details of the test we can only continue to speculate. If there is something that needs to get checked out then since we are in Japan then you would think that would not be an issue other than it being a US spec bike. I am just glad that mine was manufactured before 01 APR 2001 and didn't have to go to Tokyo for these test.
schleife
Hi,
due to the stumbling mode while driving in stock layout in lower rpm, allmost all of the Busa drivers here in Germany enrich the idle up to 5% (normally 2%). I usually do it with the Yoshi box as it's easier to maintain than to reflash the ECU.
So I'd suggest just to lower the idle mode (which works up to 10% of throttle) by, well, 2....5%, then get the testing done and enrich it again.
Should work.
At least it does with German Busas :-)
Bye
D1
Mr Bogus
Trouble Makers Inc.
Hi,
Should work.
Bye
D1
am guessing you mean the idle portion of the "map" for fuel curve? (corrects a lean tip-in stumble)
adjusting the idle speed would affect the TPS but not sure how much it is going to modify that fuel curve by 5%
Thread starter Similar threads Forum Replies Date
HayaWakened AV.TEST<audio><color> Videos 2
gurrera Bathtub Test Random Thoughts 1
Twobrothersbusa Q4 Tire Test Report General Bike Related Topics 5
08BusaKY Test drove a couple bikes today General Bike Related Topics 10
Gk1 Busa wind tunnel test General Bike Related Topics 5
1busa “Doocati” Test Rides..... General Bike Related Topics 86
groran1000 GOIN TO TEST SLINGSHOT FRIDAY General Bike Related Topics 15
Jose J Ortega Random Question... (Compression test/valve clereance) Maintenance and Do-It-Yourself 2
mabupa Oil Test Results From Blackstone Lab General Bike Related Topics 28
Rick Dorfmeyer Compressin Test All Motor 4
Tb3 Put My New Seat To The Test Today Gen II Busa Information 12
M Leak Down Test Benefits Busa problems 17
zook What Are The Guidelines On People Test Driving Your Bike Before You Sell It? General Bike Related Topics 30
S Test Bike For Qs Installation Needed, Chicago Area General Bike Related Topics 1
gurrera Your Yearly Dementia Test Random Thoughts 1
Ham How To Test Regulator?? Video Included Gen II Busa Information 6
J Went Out To The Local Dragstrip For Test And Tune And Got Some Good Go Pro Video Videos 17
Bus AZ Random Pic Test Random Thoughts 5
Terryzrx1200 picture test New Owners Forum 5
gurrera DNA Test Not Necessary Random Thoughts 4
M Go Pro's gooseneck and clamp quick test ride Videos 0
hansejo Gopro/Actioncam external microphone test: Edutige ETM-006 Electrical Mods 7
piratediverjefff GoPro Under Seat External Mic Test Videos 15
piratediverjefff GoPro Test Videos 5
jellyrug Gen III Busa test at the strip General Bike Related Topics 5
I just a video test on my other bike. made the tail lights General Bike Related Topics 0
MelodicMetalGod Project LiveWire - Test Ride Complete! General Bike Related Topics 12
gurrera Test for Old People Random Thoughts 7
R Charging Issues/Questions on test procedures Busa problems 7
gurrera Old timer's test Random Thoughts 4
P Hayabusa coils resistance test Busa problems 3
piratediverjefff Fontana Test 'N Tune Today 1/4 Mile 16
05 Busa LE 2014 MotoGP Test Twisties 8
outlawbusa Mayo Clinic test Random Thoughts 10
05 Busa LE Suzuki Tops WSBK Test Twisties 2
gurrera Here's another trick of "Doctor Dementia" to test your skills.... Random Thoughts 17
captain Help me test the new post / mark as read Random Thoughts 32
captain test Random Thoughts 11
Busabim 17 Brand Motorcycle Oill test ical General Bike Related Topics 7
Tufbusa Dunlop Q3 tire test by Dave Moss Tires 1
rubbersidedown Time to test a TIRE THEORY + Baby gots sum nu shoes.... General Bike Related Topics 6
05 Busa LE Suzuki MotoGP Test Twisties 1
T Russian scooter test drive ends in a ditch Videos 9
T New Motorcycler Helmet Test Videos 4
Bubba Zanetti GoPro Hero3 Quick Test Videos 4
G Jerez MotoGP Test Results! spoiler alert General Bike Related Topics 2
My Busa Go Pro Rear View Grab Bar Mount Test Videos 1
Pbadasay Test rode a new bmw s1000rr General Bike Related Topics 61
piratediverjefff Pepsi MAX & Jeff Gordon Test Drive,Funny Stuff Videos 7
shawnski spy picture of 2014 hayabusa ( test ride) General Bike Related Topics 37
Similar threads
Latest Bikes
  • Bam Bam
    My Last Little Girl
    • rlmoorex
    • Updated:
  • My first Busa - 2012
    Nice, clean and well looked after , my pride
    • Kimbo2570
    • Updated:
  • busa
    nice and clean again first ride since ecu reflash
    • bigjimbo
    • Updated:
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
Forum statistics
Threads
174,442
Members
48,422
Latest member
Verdell1
