Jeremy112113
Hey everyone,
I have an 05 Hayabusa with 56,xxx miles. I replaced the clutch with oem steels, fibers, and springs about 3,000 miles ago. At the same time, I overhauled the clutch master cylinder due to it sticking. When I did that, I used a mighty vac with new Dot4 fluid. I know I don't slip the clutch or abuse the clutch when I ride and only do high end pulls. It started to slip today in 6th gear WOT around 6,000 rpm. When it did this the rpm increased by about 2,000 and then dropped once it 'caught' and lurched forward. It happened again in 2nd and 3rd gear WOT around 6-7k rpm. Today was my first ride after changing the oil from Valvoline 10w-40 Full Syn to Rotella T6 15-40. The bike also does not have an oil cooler and the restrictor is removed.
My questions: would my oil be the culprit? I did some research and it isn't likely, what is everyone's thoughts? I wanted to get some insight before I actually pulled the clutch cover. Any help is greatly appreciated! Thank you.
