It can be fixed without splitting cases. Just not the "right" way.Clutch rod seal is torn can I get a new gasket I have or fix this without splitting the cases?
that would involve a lot of silicone sealant on and in the seal?It can be fixed without splitting cases. Just not the "right" way.
Aaaaahh mate, did you know the seal is contained in the case with a lip protruding a few millimeters over the face of the seal, and unlike other seals (as you described the procedure of removal and installation) will NOT just come out easily, and even if you do get it out, it is impossible to fit a new seal in without fitting it from the inside of the crankcase . . there is a lip preventing removal and install from the outside of the case.take the pushrod out , with a large phillips screwdriver, insert in the pushrod hole and prize ( that is push sideways ) the seal , it will come out ,
clean the seal recess ( degreaser on rag or similar )
new seal , wipe a very fine smear of silicone on the seal ( outer edge). now with a socket ( the same size or similar ) to the seal tap the seal in place —— keeping it even and square . lube ( engine oil ) the pushrod before you insert it
i would quote / charge 1/2 an hour for this procedure
the silicone is both a lubricant ( to help install the seal ) and will “ set “ to seal the outer seal
(...)there is a lip preventing removal and install from the outside of the case.
Not a lot, not pretty, but will not leak and get you out of a pinch. Cut the lip off and sealer around outside edge. Leave pushrod in to keep new seal aligned. Like double protection. Nobody getting pregnant here.that would involve a lot of silicone sealant on and in the seal?
not exactly the 'right' way, but it is ONE way lol.
Improvise, overcome, adapt! Awesome!N
