Really?Let us know how that goes.Smaller bores create more pressure. They are also harder to pull. I'm running 14 on clutch and 15.8 on brakes. Gonna change brakes down to 14 for more stopping power.
Cheers man.i can't remember..
But the general consensus is, replacing with Brembo:
16 for the clutch
And either a 17 or 19 for the brake.
The R1 Brembo is a 17
Excellent info Frank, thanks, I'll be writing that down in my notebook.or other way around
the original dia at clutch and brake pump is both 5/8"
at the front brake
the radial 17 piston dia i like to use on the street
the radial 19 piston dia i only use at race track
the danger of overbraking the front with the 19 in "fear / shock braking" is for me toooooo big
clutch and a radial 16 piston dia is, i guess, the best combination
and
if the ´99 / ´00 slave doesn´t work best try the slave of the 2002 and later (gen2´s fits also).
their piston dia ist 36 mm instead of 38 at the ´99 / ´00 (and i suppose ´01)
Hi. My Beringer brake master is a 20.6 mm. I will have to look into the clutch master. They are the same ones that DME uses. But what do they know they have not ran under 6.38 sec or faster than 232,59 MPH in the 1/4 mile.Excellent info Frank, thanks, I'll be writing that down in my notebook.
Thanks for the info.Mine is a 2014.Do you know the caliper piston diameter?or other way around
at the front brake
and
Thanks for the info(...)
(...) .Do you know the caliper piston diameter?
As far as I was aware the diameter of the master cylinder bore that’s optimum is based on the caliper piston size.your welcome
what for?
even i never took the dia of my ´00 tokicos - why should I?
I have a brembo radial from a Superduke R1290 ready to go on.Helibars also ready.It’s just a case of making time for it now.@murphc13
for the original tokicos at the gen1´s front brake i stay with what i wrote above
"the radial 17 piston dia i like to use on the street
the radial 19 piston dia i only use at race track "
the combination of deep cleaned (all ~ 24kmi) calipers and a 17 radial pump is so very /highly sensitive - you won´t spend a lot of money for other things - believe in me - more you don´t need (on the road).
Hi guys.Just a quickie to find the bore sizes for replacement.
I’ve read somewhere someone changed the clutch to a bigger bore size and regretted it and went back to stock.
Any help is appreciated.
@Mythos
big error, that i made too - the bore size you can´t adjust - it is fix !
what you only can change is the distance between throttle grip and brake (or clutch) lever
(depending on the length of your fingers / hand size)
the writing(s) on the pump, e.g. 16-18 say (according to several phone calls with brembo-germany, Munich ), that (in this example)
16 = dia of piston in "mm"
18 = distance in "mm" between lever´s screw (lever´s pivot point) and piston´s pin / connecting point to the lever
i built an excel sheet to calculate (according to the leverage laws) the delta between resulting pressure in the system when
standard "tangential" (5/8" piston) or a "radial" pump (16mm piston) is in use
5/8" = 15,875 mm (very close to 16 ;-) )
result:
the delta pressure is (at radial 16-18) ca. + 40% higher in the system when the hand force is the same.
other way arround - with same hand force the brake works better / get 40% more pressure
(other radial´s piston dia, other pressures, e.g. 17-19 : ca. + 30%)
reason: the leverage at the "tangential" is "worse" than at the radial -
when
precondition - both piston sizes are nearly the same.
I think the best thing to do is to go with recommendations.
