Ok, before condemning the clutch pack, let's go back to basics . . .
First . . check the hydraulics, the actuation mechanism, from the lever to the master cylinder, to the hose/pipe, to the slave cylinder.
You must NOT overfill the reservoir with fluid, this could cause the clutch to slip. There MUST be a gap above the fluid level to allow for expansion and fluid level movement.
You must be certain the slave cyl piston is actually moving out under hydraulic pressure (when you squeeze the lever) but not only moving out (to push the push-rod) ,
but also RETURNING to release pressure on the push rod, and to allow the clutch plates to lock up and to give drive again.
If the m/cyl piston is
not fully returning, the clutch will slip.
If it is established beyond a shadow of a doubt that, yes, it is returning and there is no more pressure on the push-rod, good.
To verify and test this, remove the sprocket cover (that houses the slave cyl) and manually push the piston back as far as possible, then give the clutch lever a couple of pumps and watch the piston move out.
Then push the piston back, repeat this a few times to be sure the piston is not sticky and causing the clutch slippage.
Also, check the push-rod is straight and not bent,
and finally be sure the clutch plates are installed in their correct order according to the service manual's instructions.
That is a "start to finish" clutch check procedure . . . Kiwi style!
