Clothes Dryer Won't start
yamahor
DEAD MAN WALKING
So, Any one know how to troubleshoot a clothes dryer? Here's what I know...
It was working fine, mom cleaned the lint trap (which is right below the start button) and now it won't even try to start... My thought is over the years, lint built up in the Start button causing a bad connection, but that's all I can really think of aside from the door safety switch (what prevents it from running with the door open) being broken... Any ideas?
Wag
Evil Demon Busa Rider
The door has a little "prong" that sticks into a little hole in the door frame. There is a little lever in there which acts as a switch. The hard part is getting any access to it but if you can poke a wire to press that switch and then press the start button, at least you'll know.
Proceed from there.
--Wag--
BA BUSA
MotoGP Wannabe
(Wag @ Dec. 25 2006,12:13) The door has a little "prong" that sticks into a little hole in the door frame.  There is a little lever in there which acts as a switch.  The hard part is getting any access to it but if you can poke a wire to press that switch and then press the start button, at least you'll know.
Proceed from there.
--Wag--
A couple of "Brain Sturgeons" we have here
Door safety switch...prong thingy
Is it plugged in
Did you check the circuit breaker
Dryer usually has it's own breaker.
yamahor
DEAD MAN WALKING
(BA BUSA @ Dec. 25 2006,15:17)
Proceed from there.
--Wag--
Is it plugged in
No, I'm a Crockpot Scientist...
Yes, it's plugged in (Durrr)
Yeppers, checked the Breaker.
yamahor
DEAD MAN WALKING
(Wag @ Dec. 25 2006,15:13) The door has a little "prong" that sticks into a little hole in the door frame.  There is a little lever in there which acts as a switch.  The hard part is getting any access to it but if you can poke a wire to press that switch and then press the start button, at least you'll know.
Proceed from there.
--Wag--
Checked the prongy thingy... It springs in and out, seems to work. I'll try and take it apart soon to see if a wire came loose.
Busa Dude
Check the breaker in the electrical box, Check the pig tail were it mounts to dryer, if all ok door switch , start button , or the motor its self, if running but not heating overheat protecter or heating element, not to many parts to a dryer, I'm not a repair man but I did sleep in a Holliday Express last night
BA BUSA
MotoGP Wannabe
(yamahor @ Dec. 25 2006,12:20)
Proceed from there.
--Wag--
Open er up and see if you have any reset buttons
yamahor
DEAD MAN WALKING
(BA BUSA @ Dec. 25 2006,15:22)
Proceed from there.
--Wag--
Buttons?
Okay, do I press the red one labeled "Self Destruct: Do Not Press!!!"?
yamahor
DEAD MAN WALKING
(Busa Dude @ Dec. 25 2006,15:21) Check the breaker in the electrical box, Check the pig tail were it mounts to dryer, if all ok door switch , start button , or the motor its self, if running but not heating overheat protecter or heating element,  not to many parts to a dryer, I'm not a repair man but I did sleep in a Holliday Express last night
Cool, I'll check those. Thanks for staying at Holiday Inn Express!
BA BUSA
MotoGP Wannabe
(yamahor @ Dec. 25 2006,12:24)
Proceed from there.
--Wag--
Buttons?
Yeah thats the one...........BOOM
yamahor
DEAD MAN WALKING
Auto post:
The member known as Yamahor will no longer be posting as he is in a full body cast thanks to listening to BA Busa... Gee Thanks BA Busa for ridding Hayabusa.org of its coolest most awesome-er-est member... You will be hearing from our lawyers.
ranman
busaless but lovin the weather
if i cant get the washer or dryer started i ask her if she has been loseing weight
sorry pal no help here
xzvs
Last time mine did this it was actually starting but the belt had broken that drives the drum -- new belt -- problem solved
they can actually be pretty complicated (timers overtemp sensors ect )
usually if its not a belt or a tripped breaker -- its cheaper to get a new one (or good used)
Spike
Also the electric socket itself may have a "Ground Fault Interrupt." Generally a little redsih looking button that even when tripped doesn't look like it. If you have one on the plug in the wall just depress the red button.
Also sometimes just unplugging it for a short time can reset any caps that may have overloaded.
Just a thought.
yamahor
DEAD MAN WALKING
(Spike @ Dec. 25 2006,15:31) Also the electric socket itself may have a "Ground Fault Interrupt."  Generally a little redsih looking button that even when tripped doesn't look like it.  If you have one on the plug in the wall just depress the red button.
Just a thought.
Cool. didn't think to check for the GFCI switch.
Latest Bikes
Forum statistics
Threads
177,966
Members
50,521
Latest member
Northernstar
