Checking shift rods
Purple1300
I remember posting on here a while back about difficutly shifting. It wasn't too bad but I didn't think it was as smooth as it should have been. NOW it's just sucking, especially when I down shift. So someone told me maybe it needs to be adjusted or the shift rods are going bad. How easy is it for me to check them in my garage and what do I check for?
Ummm...the shift problem "could" be the rod, but that's one tough sucker, I'd check your fluid level first. You know, flush, replace, yada....
If you're going to check the rod itself, put the bike on a rear stand, remove left side fairing, move the coolant bottle to the left as you face the left side. I usually swaps holes, and hang it on the forward, threaded hole. Disconnect speed sensor on side of sprocket cover, small allen head and swing it out of the way. Take a 10mm wrench and loosen the bolt on the shifter linkage that connects it to the transmission. Remov it and slide linkage off of shaft and let hang. Take a 12mm wrench, and a 12mm socket w/ ratchet and remove sidestand sensor. Now that the wires and stuff's out of the way, take a 8mm socket on a 1/4" drive with extension and take out four screws that secure cover on side of transmission. Slide cover slowly off, and inspect rod. On a rear stand you can actually remove the rod without much oil loss, but if leaning to left on side-stand, it will leak oil. See that rod is clean and inserts smoothly without much resistance.
Now replace in reverse order.....is it shifting hard at the foot, or is the lever hard to pull in
My bad...I thought you meant the clutch rod, are you referring to the shift "forks"...
i think she meant shift forks. I would like to know the same. A buddy of mine said that you can replace the shift forks without cracking the cases. Said you could drop the oil pan and do it. Is this true?
yeah shift fork i also need to know mine is not shifting as smooth as it used to but it miht have to go into the shop this winter get a new clutch and shift forks
You have to split the cases to do the shifting forks.
