clean
Hi Guys,
finally got around to checking my valves today. I have searched the forum / done some reading, and come to the conclusion that there is varying opinion on the subject .
When I say "varying opinion" I mean where should we be setting the valves? at max? in the middle? on the tight end? is measuring in inch sufficient or should we be using a fine increment metric feeler gauge set?.....I for one don't have a clue
Anyway, my intakes were all at roughly .005 (basically in the middle of the spec) some were a little tighter for the .005 to go through, but it went though on all without "too much" force - .006 would not go through on any intakes.
The exhausts however were tight across the board - two at .005, two at .006 and the rest at .007
I wanted to get some ideas on what you guys think I should set the exhaust to? I have heard going to the max is best for longevity, but I have also heard its risky, and in worst case could cause a failure. this bike is basically going to remain stock with maybe an aftermarket exhaust - nothing crazy. I'm thinking .010 ?
or should I be getting myself a finer feeler gauge and re-measuring?
thanks for any, and all input.
