Cheap engine stand
Bigboy Busa2
Bought the stand at harbor freight. Under $50. Wanted stand for new motor and improvised on one I seen for$100. Yes it's an old 3/8 extension I had beat on and it worked perfect. Nylon strip at bottom to cusion the case. I used the plate that came with it as you see and the size was perfect. Just took motor off stand so I painted
This is so cool!! You’ve inspired me to make me one!
something like that is only useful for working on the head or block or possibly for dismantling the oil pan on motorcycle engines.
but if the gearbox/transm. is the goal of a work, the only thing - 4 head down - that helps is a stand analogous to the one I'm showing here (for head up).
a bit of angle and flat steel, a few thicker screws and a welder and the stand is done.
