Charging system
killertiller
I’m just about ready to put the stator in my bike but I want to make sure that’s my problem. When battery is fully charged it reads 12.8 And charges 13.8 at 4000 rpm. after running at idle for 10 minutes read 11.0 at idle and 11.0 at 4000 rpms.
Kiwi Rider
Always check the stator output FIRST.
Possible faulty regulator/rectifier, when the fault occurs and the reading is 11v, check the voltage (AC) output from the stator phase wires, should be around 65v to 100v AC on each phase, depending on RPM.
If that output reading is correct, replace the regulator then recheck charging rate at the battery, should be over 13.2v at 2000rpm constantly and not drop away.
Kiwi Rider
be sure to watch this explaination, VERY well laid out!
killertiller
Thanks guys im more of a parts changer then parts tester.. lol. But i think i can figure it out. Does the rectifier have to me mounted to work? Cause i can easily just plug the new one i have in and see if anything changes in few seconds.
killertiller
Im at dead end.. battery tested perfect its a year old.. stator and rec tested perfect.. i tested both 5 times even checked the stator from plug at stator and at rectfier. Only thing that was odd was when guy tested batter he just hooked up tester for 1 second n said its good.. i had a tester years ago and i remember having to hit button to put load on battery.. maybe thats old school ..lol
killertiller
Now battery is 12.8.. when turn key its at 12.00. When i hit starter it goes to 10.8 for a second then fires and shows 12.0
killertiller
For heck of it i plugged other rectifier in and its reading good.. maybe to good. Idle about 12.8 when i rev to 5k its 17.2... is that too much? The stater is pretty warm but you can touch it.
killertiller
Final update..lol Went back out to check the numbers one more time and everything seems completely normal when it’s revving is charging at Between 14.2 and 14.8.. at idle 12.8.. Thanks for the help guys
Kiwi Rider
Ya see, it just ain't that hard testing electrical equipment now is it?
The problem is, you've gotta do it a lot to become competent and confident at doing it and UNDERSTANDING what you are actually doing.
So just practice at it and test every system you can, you'll be a bloody expert in no time! :beerchug:
Kiwi Rider
These new fangled electronic load testers do only take a few seconds or less.... I prefer the old school actual load test with a carbon-pile type load test. That's the honest-no bullsh%t test, but it has to be done carefully on bike batteries.
You load up the battery to half of it's CCA capacity for 8 seconds or so, watch the needle drop the voltage.
Or, just crank the engine over and watch the voltage drop. If it drops below 10v after a few seconds of cranking, recharge the battery, let it rest for and hour or so, and retest with cranking.
About 10V is the threshold whilst cranking.
Anyway, sounds like you've sorted it. Good job mate! :beerchug:
killertiller
So rode today then tested.. its back to high volts... at 4000 rpms it charging at 18... Talk to a mechanic friend of mine and he said sometimes you have to change them as a set the rectifier and stator?
Thread starter Similar threads Forum Replies Date
Sandow Hayabusa Charging system tips , and usage of watts (c10's Garage) General Bike Related Topics 6
ky busa Gen2 charging system problem General Bike Related Topics 2
killertiller Charging system General Bike Related Topics 0
W How many Watts can I pull of a 2006 busa charging system Electrical Mods 2
I Charging System or what? Busa problems 7
IG. Problem with charging system General Bike Related Topics 3
K HIDs and charging system General Bike Related Topics 1
Busa1166 Charging system failure General Bike Related Topics 2
race24x Charging system issue Busa problems 5
thapp charging system not hayabusa Busa problems 0
Ban-One charging system General Bike Related Topics 2
mrnyc01 24 volt system charging Busa Mods 13
S upgraded charging system? Busa problems 0
J dual battery charging system Busa Mods 5
F Charging system Busa problems 1
J Higher output charging system?? Electrical Mods 11
2quik Charging system power..??? General Bike Related Topics 13
C Charging system output?? Maintenance and Do-It-Yourself 4
Narcissus Charging system Busa problems 4
mike miller Anyone running dual fans have charging issues Electrical Mods 2
J Be Careful Charging Batteries General Bike Related Topics 5
D Charging issues Busa problems 5
ky busa Gen2 charging issues still General Bike Related Topics 11
ky busa Charging issues General Bike Related Topics 5
GXR1147 Gen 1 charging woes Busa problems 4
V Charging issues Electrical Mods 6
groran1000 Got safety recall today in mail charging rectifier General Bike Related Topics 16
Busa1166 Charging/stator Problem Busa problems 4
piratediverjefff Gopro Remote Not Charging Off Topic 3
Robert Waldron Charging Prob. Busa problems 6
DUNK Charging Problems Busa problems 2
DUNK 2000 Suzuki Hayabusa....charging Problem General Bike Related Topics 0
dave s Regulator Charging Volts Busa problems 10
EchoBase First Gen Charging Issues Journey Electrical Mods 4
N Charging people for a dirt bike ride on a personal track. General Bike Related Topics 17
K Battery Charging Question General Bike Related Topics 4
R Charging Issues/Questions on test procedures Busa problems 7
Yunus 06 Busa charging issue Electrical Mods 8
medic357 having charging problems PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Busa problems 8
Hayabusa133 Charging Voltage??? Busa problems 13
D Battery Charging Issue Gen II Busa Information 7
A charging problem General Bike Related Topics 11
efiguero Stupid question, but curious, Will Charging my iPhone overnight kill my battery? Gen II Busa Information 10
M My version of a charging issue, seems a bit different than what I've read about. Busa problems 13
A 2008 hayabusa charging help! General Bike Related Topics 12
B Charging issues Busa problems 4
V Battery not charging & overheating Busa problems 14
PhillB Charging problems in XTR2 car Busa problems 11
S Battery, Charging, Whats wrong with my baby? Busa problems 6
B How to check a charging hayabusa Busa problems 2
Similar threads
Latest Bikes
  • My first Busa - 2012
    Nice, clean and well looked after , my pride
    • Kimbo2570
    • Updated:
  • busa
    nice and clean again first ride since ecu reflash
    • bigjimbo
    • Updated:
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
  • New guy here
    • Los.great.beard
    • Updated:
Forum statistics
Threads
174,396
Members
48,397
Latest member
ManiacJack
