i was looking to see if it is safe to add driving lights to the busa while i'm highway driving at night ...wanted to know if output was enough so i would not run down the batt.since the busa starter is delicate I would be cautious about running the battery down......starting the busa with a low battery could cause major damage
actually HID lights draw LESS power than stock, regular, bulbs.HID is hard on the system and that is why people that drag busa with HID have seperate switches to kill the headlights on the frequent short runs and starts. I think that you would be okay to add some lights as long as they were not to intense.
+1 HID does draw less than the stock lightactually HID lights draw LESS power than stock, regular, bulbs.HID is hard on the system and that is why people that drag busa with HID have seperate switches to kill the headlights on the frequent short runs and starts. I think that you would be okay to add some lights as long as they were not to intense.
the reason why they turn them off and keep them from turning on and off is bec its bad for the HID igniter.
forgive him for he knows not what he sez...HID is hard on the system ....
As per Chapter 8 (Servicing Information) Page 52 of the Hayabusa Service Manual, the alternator’s max output is rated approximately 400 Watts @5,000 RPM.Iwas wondering ir anyone knows the output of the busa's charging system as i wanted to add some extra driving lights and the Service Manual does not tell you ..Thanks ...
That's what I had thought. Someone above said that starting with a low battery could cause "major damage."actually HID lights draw LESS power than stock, regular, bulbs.HID is hard on the system and that is why people that drag busa with HID have seperate switches to kill the headlights on the frequent short runs and starts. I think that you would be okay to add some lights as long as they were not to intense.
Thank-you i see i won't have any discharging issue's then thats what ineeded to know ...As per Chapter 8 (Servicing Information) Page 52 of the Hayabusa Service Manual, the alternator’s max output is rated approximately 400 Watts @5,000 RPM.Iwas wondering ir anyone knows the output of the busa's charging system as i wanted to add some extra driving lights and the Service Manual does not tell you ..Thanks ...
The regulated voltage output is: 13.5~15.0 volts @5,000 RPM
The current potential may then be derived using Ohm’s Law.
Wattage/Voltage = Current
Assuming a max charging voltage of 15 volts is present:
400 Watts/15 Volts = 26.66 Amp potential current delivery
Assuming a charging voltage of 13.5 is in use:
400 Watts/13.5 Volts = 29.62 Amps potential current delivery
As you can see, the charging system puts out far less than the 90 Amps suggested in one of the previous posts. I hope you find this helpful.
