Charging issues
Dcroes92
1st gen hayabusa 2004 not charging
Measured continuity between 3 yellow wires all reading 0.4 ohms
Measured AC voltage from stator when reving 60+ volts
One of the wires doesnt have voltage at all when revving the engine...
Do all three wires are suposed to have voltage or only 2 of them?
The yellow wire with 3 black dots is the one that isnt charging
But does measure .4 ohms
Dcroes92
If it ain’t charging at the same AC volts as the other two phases, it is faulty.
Also, test it for continuity to ground, do you have a manual? Go through the ground testing with your meter.
No manual
But could it be faulty even if it has continuity between the 3 phases?
Berlin Germany
Believe it or not - yesterday! afternoon I had such a problem with too little battery power at a freind´s 2002 hayabusa.
Only just 12.9 - 13.1 v came to the battery from rectifier/regulator.
result: no charging - on the contrary, the battery was getting weaker and weaker.
So I disconnectet the 3-point plug under the gas tank and measured the 3 poles of the stator against each other - 65-70V.
so far it looked ok, so what (b..llsh..t) happens there? (i "sell" an "u" and an "i") ;)
i cleaned ANY pin in the main plugs under the tank and the regulator ´s plugs in the rear by contact spray , re-connected all again, and? still low voltage at the battery.
my curses were definitely not youth-free !
i again disconnected the stator´s 3-point plug under the gas tank and connected both plugs (m & fem) by 3 flying testing 2.5² wires to meassure the voltage when motor is running and lights are on.
result : voltage was arround 12.4-12.9 v
damn, thats not ok, too low
then i changed the stator and meassured the same way like before
and ?
13.0-13.5 v now - regulator was connected properly, motor running + lights on - okayyyyyyyyyyyyyyy
then i meassured the voltage at the battery poles and i found 13.9 upon there. YES! 10 of 10 (bowling)!
with that voltage the battery should be charged again properly - but a "long-term test" is still pending.
perhaps this description may help - i hope so.
Thread starter Similar threads Forum Replies Date
mike miller Anyone running dual fans have charging issues Electrical Mods 2
ky busa Gen2 charging issues still General Bike Related Topics 11
ky busa Charging issues General Bike Related Topics 5
V Charging issues Electrical Mods 6
EchoBase First Gen Charging Issues Journey Electrical Mods 4
R Charging Issues/Questions on test procedures Busa problems 7
B Charging issues Busa problems 4
J Be Careful Charging Batteries General Bike Related Topics 5
Sandow Hayabusa Charging system tips , and usage of watts (c10's Garage) General Bike Related Topics 6
ky busa Gen2 charging system problem General Bike Related Topics 2
killertiller Charging system General Bike Related Topics 0
killertiller Charging system General Bike Related Topics 13
GXR1147 Gen 1 charging woes Busa problems 4
groran1000 Got safety recall today in mail charging rectifier General Bike Related Topics 16
Busa1166 Charging/stator Problem Busa problems 4
piratediverjefff Gopro Remote Not Charging Off Topic 3
Robert Waldron Charging Prob. Busa problems 6
DUNK Charging Problems Busa problems 2
DUNK 2000 Suzuki Hayabusa....charging Problem General Bike Related Topics 0
dave s Regulator Charging Volts Busa problems 10
N Charging people for a dirt bike ride on a personal track. General Bike Related Topics 17
K Battery Charging Question General Bike Related Topics 4
Yunus 06 Busa charging issue Electrical Mods 8
W How many Watts can I pull of a 2006 busa charging system Electrical Mods 2
medic357 having charging problems PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Busa problems 8
Hayabusa133 Charging Voltage??? Busa problems 13
D Battery Charging Issue Gen II Busa Information 7
A charging problem General Bike Related Topics 11
efiguero Stupid question, but curious, Will Charging my iPhone overnight kill my battery? Gen II Busa Information 10
M My version of a charging issue, seems a bit different than what I've read about. Busa problems 13
A 2008 hayabusa charging help! General Bike Related Topics 12
V Battery not charging & overheating Busa problems 14
PhillB Charging problems in XTR2 car Busa problems 11
S Battery, Charging, Whats wrong with my baby? Busa problems 6
I Charging System or what? Busa problems 7
IG. Problem with charging system General Bike Related Topics 3
B How to check a charging hayabusa Busa problems 2
S charging voltage Gen II Busa Information 6
K HIDs and charging system General Bike Related Topics 1
Blanca BusaLess GoPro cooked itself charging on my Pc General Bike Related Topics 38
J Winter battery charging Gen II Busa Information 26
Howabusa Not Charging Busa problems 3
kairles A little confused, charging problem? General Bike Related Topics 20
H how long will it take to kill the batt with a gps charging Gen II Busa Information 9
Busa1166 Charging system failure General Bike Related Topics 2
m_ridgeway Charging problem. need help Busa problems 3
race24x Charging system issue Busa problems 5
R Charging and surging need help Busa problems 1
W Large Current draw and no charging Electrical Mods 1
Chopstix how do i know if my chatterbox gmsr-x1 is actually charging? New Owners Forum 4
Similar threads
Latest Bikes
  • Bam Bam
    My Last Little Girl
    • rlmoorex
    • Updated:
  • My first Busa - 2012
    Nice, clean and well looked after , my pride
    • Kimbo2570
    • Updated:
  • busa
    nice and clean again first ride since ecu reflash
    • bigjimbo
    • Updated:
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
Forum statistics
Threads
174,440
Members
48,421
Latest member
Busa2004111111
