Remove the left side faring, remove the three bolts that hold the sprocket cover/clutch slave, ( I remove the chain as I replace both the front and rear sprockets and chain at the same time, bend tab down off of sprocket nut, put bike in gear, use impact gun to remove nut, slide sprocket off.
