Kerosene to clean
Dupont teflon dry chain wax aerosol spray lube
I use WD-40 to clean, then I dry, and lube afterwards. Works great; and WD-40 will not harm 0-rings. Motorcyclist magazine did some testing with it (soaking the o-rings in it for days and had no issues). It's a great cleaner, not a lube though.
So im guessing kerosene won't harm the O ringskerosene to clean and I use BelRay chain wax. Never had any sling from this stuff. I love it. Some folks use wd40 to clean it. Ive tried it but it seems more messy to me any way.
I figured i give the grease ninja a shot, looks like a solid product. Plus they are local to me.I usually use Motul chain cleaner(which is probably mostly kerosene)and lube,wipe off excess and let sit overnight.One of the handiest gadgets I've found is called Grease Ninja,does the best job ever of lubing your chain in about 15 seconds with hardly any waste or mess.
http://www.greaseninja.com/Chain-Lube-Accessory.html
http://www.canyonchasers.net/reviews/accessories/grease-ninja.php
Really? I mean i have read in the hayabusa's manual that never use kerosene as a cleanerNo kerosene will not harm your o rings. If fact that is what suzuki recommends using to clean the chain.
Even though this is a 4 yr old thread, you can use Kerosene to clean your chain with no issues at all.Really? I mean i have read in the hayabusa's manual that never use kerosene as a cleaner
