Can you shift gears with engine off?
Busa3Fan
When the engine is off, can you shift gears like you normally do with engine on?
I noticed that this cannot be done on many motorcycles, including Hayabusa.
Why is the gearbox not working with engine off like it does with the engine on?
Super curious! :)
@Busa3Fan
lift a motorcycle (engine off) , like the busa, at the back so that the rear wheel is free and rotate it back and forth while moving the shifter.
then you can shift up and down again - but really only then.
the gearbox (the trans) itself is built "sequentially" , which is why you can engage 1st or 2nd gear when stationary, but you cannot shift up further,
when the engine is off or the rear wheel is stationary.
