Kevin Jones
Conditions given, a wheelie that keeps rising off the line until you have to let off the gas/clutch it/back brace/whatevertosaveyourass. Would increased rebound damping help bring the back wheel up and change the fulcrum to bring the front wheel down or do you need to reduce rebound to help that? Is rebound damping capable of any of those things? Do you have a particular setting that you think is a medium or set to maximum or minimum rebound damping? I have tried to read and understand these things and I am not grasping suspension tuning and getting frustrated. Most of my problems experienced, stock gen 1 shock and a 4" extension on a 230hp bike and now that I have extended the swing arm, I find I really dont know what I am doing. It will take forever to try to figure these things out with experimentation if I dont understand the basic concepts. I have been told what to set it at basically with sag and compression but that really will only go so far with me. I have to understand concepts. It is even more frustrating since I understood how to make a 4 wheel hook up, well, actually I never had that much hp to have to really really tune suspension other than buy add ons.
My current set up:
trac dynamics 465 HD shock (I couldnt afford a penske)
10" setting on swing arm (bringing in a little, spins violently, prolly to 8")
Stage 1 turbo (mild tune @230, HD clutch springs, 17/44t combo)
I weigh 170 suited.
I do not and will not strap down the front end at the track.
Launching at 3k since 4 spins me to the tach (on road, not track) all through 2nd, even with a babied clutch, pinned throttle right before tach before shift to 2nd.
I have yet to track test the 10" stretch and have been advised to bring it in to 8.
My current set up:
I weigh 170 suited.
