Can i use a dry 50 shoot and not hurt motor
dragbusajoe
I have a 2003 busa it made 163 with extened swing arm i was told that is very good i have a 50 shoot now is it safe to use with out fear of blowing my motor
thepushercg
veni vidi vici
go with 40 shot with the stock, your playing with fire on the 50 you could get burnt.
mestona
Greg is there a way to add extra fuel using the ECU editor only when spraying? I want to spray on a button, but I don't want the ECU adding fuel all of the time, only when I hit the button....
bobber
according to ryan at schnitz racing,,[you can pull up the chart in the NOS section,,,a 50 shot[ #38 jet] you need to add 17% more fuel at 100% throttle,,ussually starting at 7000rpm,is where I have mine at,,Im useing a 40 shot with 16% more fuel,by way of P.C,,at 7000 rpm,,,you only need 15 % for a 40 shot by their standards,,when i first got my kit,I made 1 run without a PC and my cans where burning up,,,its too lean and youll cook the pistons,,,,plus you have to add more fuel with the NOS to get the 40 HP,,so if you use a 40[#34} jet hp shot without more fuel,,you will not have 40 extra hp,,when i bought my PC soon after,,,it made a huge difference,,,and the motor stays cool,,,,,some companys recommend[such as pingel} to aim the nozzle at the temperature control switch in the air box so when the NOS hits it,,it tricks the ECU to think its still in warm up mode and gives you 10% more fuel needed for the Nos,,,[see pingels website],,,I opted for PC,,and the 2lb bottle hidden in the hump,,schnitz,has a all steel braided line kit that is sweet,,,,Im like you,,,I dont want to cook my motor,,,you can call them or browse their websites,,,,good luck,,,,
jeepinocala
Did you make your map from a dyno or ? Will you post your map?
bobber
I placed as directed my single nozzle in the front of the airbox like smithabusa did,,,ryan at schnitz racing reommended it,drill the hole right between the 2 ram air inlets,,then the Nos when activated has to go to the upper floor thru the filter to the throttlebodies for an even distribution,,exspecially if you still {like I do] have the factory stacks,,,,,I had my map tweaked to the max,,,no surgeing,and a boatload of power even without the NOS,,,,,,I will post for you when my wife gets home [she knows how to drag the maps out of the dynojet file,,and I will post it,,,,,It took me 3 good tweaks to get this right,,,,try the map,,if you dont like it,,just pull it out,,all bikes repond different,,but im running a bonstock busa[cans and all] its an 04,,ive had it since new,,when I post the map...I;ll show you where I twaeked it in the low range and the added fuel at full throttle,,,,I will try to have it up for you this evening,,,,,,,by Gods grace this bike is now nasy fast,and the motor stays cool,,It will bring the front wheel staright up in 3rd just bt hitting the 40 shot,,,,smithabusa is correct,,,you can have all he best parts in the world,,,but it has to be tuned,,,my bike is running like a madman with just a 40 on it
outlawbusa
1 wheel up aero testing
+1
I've seen 40 be ok and 60 float valves on the stock motor when run hard enough, so personally I'd stay away from the 50 shot~!~
PS: Keep in mind that's WOT for a longer period than most will run, so...in the 1/4 my guess is it might be ok
bobber
My wife had to over lay to get the whole map up,,so it looks like 2 maps,,but the bottom map is a over lay at about 6000 rpm;s,,,,,and if you noticed,,I added 16% instaed of the 15%,, shcnitz wanted 15 % over the factory dyno map from dybo jet which was 8% already and that wouldve put the extra fuel at 23%,,,,,,at 100% throttle at 7000 rpms,,,,,I opted for what you see and im glad I did,,,I get to run it without NOS and it feels like a 20 hp boost with this map alone and its insane with it picking the front tire straight up in the air at 8000rpm in 3rd on a roll on hitting the NOS ,,pm me if you need anything,,,,,,,,,bobber,,,,,,,p.s...God blessed me today with a brand new set of pilot powers....
Thread starter Similar threads Forum Replies Date
Aly Kabil Dry kit for gen2 questions Nitrous 55
U Anyone running Dry sump with Pressure Stage? Engine and Performance mods 11
RacingJake Dry kit on B King B-King General Discussion 31
M Nlr Dry Sump Track and Racing mods 2
Franknbeans Dry Sump or wet for Busa Kit Car? Engine and Performance mods 0
cavenposs E85 and Dry Nitrous Nitrous 8
cwalker2 PCIII dry shot values Nitrous 0
Mythos Brake line change, what if my master cylinder goes dry? Busa problems 8
D How much fuel with 60 Shot Dry? Nitrous 3
0 Dry Nitrous installers around Memphis, Tn Nitrous 1
S cold fusion nitrous dry kit Nitrous 9
V Lasik/Contacts cause dry eyes General Bike Related Topics 7
Busaman5000 Dry itchy skin Random Thoughts 12
California Kid What kind of leaded fuel to use with dry nos Nitrous 23
fadiizzaldin Dry NOS for Gen II Nitrous 13
A When do you guys recommend a dry sump system? Engine and Performance mods 1
fadiizzaldin Dry Nos Air/Fuel Ratio Nitrous 9
S Dry Sump Gen 1 Busa All Motor 6
Casperle Everyone be careful with your fireworks in dry areas. Random Thoughts 9
Kaptain Kanji Another good DRY LUBE for chains. General Bike Related Topics 5
X Wiring dry nitrous on Gen2 using ecu editor Nitrous 23
Takeuon Last minute *Reminder* Robbinsville is a dry county..... 2010 Spring Bash 10
Dirtanion1 dry nitrous setup questions Nitrous 9
A how much are you guys spraying (dry shot) Nitrous 6
ROCKSTEADY Dry shot for 08 made simple Nitrous 2
Nicholas Dry Nitrous Kit Questions Nitrous 13
ROCKSTEADY dry kit help Nitrous 20
J What are you dry spraying? Nitrous 9
ham4864 wet vs dry Nitrous 7
ogre dry nitrous manifolds Nitrous 4
B Dry nitrous kit and install Gen II Busa Information 22
A need dry shot advice Nitrous 4
Ryan Schnitz Spyder Dry Nitrous Kit Nitrous 2
B-12 Whats the biggest dry-shot ? Nitrous 12
tobefast.com Nitrous Express Dry Nitrous Kit Sale Nitrous 0
Projekt A hot and dry desert night Random Thoughts 9
W Pcv auto tune for dry nos ? Nitrous 2
Dr151 Dry Shot on the '08 (pertaining to '08/09's only please, less confusion) Nitrous 46
lika1 Dupont Multi-use Dry Wax Lubricant Gen II Busa Information 4
Busa_Nick STIHL BR600 Leaf Blower to dry the bike after washing!!! General Bike Related Topics 11
brett Anyone tried a dry clutch set-up? Track and Racing mods 4
Lurch Home safe and Dry 2009 Spring Busa Bash 16
Kento-Moto Calif Dry weather ride Feb 20, 2009 General Bike Related Topics 14
B@DA$$08BUS@ 08, Dry NOS Nitrous 4
lensflare please help me entering in the DRY world... Nitrous 9
HillbillyTom Sunny And The Roads Were Dry.. General Bike Related Topics 15
rc51ny GARMIN QUESTION-Keeping it Dry General Bike Related Topics 26
J What is needed for a dry nitrous kit to stock bike hayabusa? Nitrous 4
Gixx1300R ** Dry Nitrous Spraybars ** Nitrous 41
Draco1340 Dry Shot ?? using USB PCIII USB Hub Nitrous 14
Similar threads
Latest Bikes
  • A blue bike
    2017 blue & black
    • Hayabusa Wannabe
    • Updated:
  • 2011 busa
    • Hetheus
    • Updated:
  • New guy here
    • Los.great.beard
    • Updated:
  • My 2014 Hayabusa
    • Dljat2
    • Updated:
  • Hi Everyone
    Loved
    • BirolBora
    • Updated:
Forum statistics
Threads
174,195
Members
48,297
Latest member
Richbusa
