I bought a "replayXD 1080" for my bike and it came with a 4gb SDHC card.
How many hours of recording is that?
I was thinking of getting a 32gb SDHC card for my camera, does anyone know how many hours a 32gb card would be compared to the 4gb card the camera came with.
You can get a 32gb card online at walmart for $50...sandisk..
4gb card about an hour record time
With 16gb card on 920 setting gets me about 2 to 2 and a half hours record time...
With 32gb card i get about 5-6 hours of record time..
I would suggest getting the battery bac pack also...with regular battery you only get 2-2.5 hours of run time...with bac pack you get 5-6 hours of record time..
Also check what class the card is. Cheaper cards are usually a lower class number and write slower. This affects the video quality. It's not all about size...
I use Kingston Sdhc card in my gopros and never had any problems. I tried cheap nonage cards and they were a waste of money. I'm sue they are ok for using to transfer stuff, but they couldn't keep up with the demands of recording HD.
I have a Go Pro HD2 and use a class 10 16 gb card. I feel its best bang for buck when you look at cost and space available. Also . if you plan to take full HD videos , i suggest you use class 4 or higher cards. 1080p should give you around 2 / 2.5 hours of recording on a 16gb.
Read the owner manual and it should recommend a minimum class for that card. Most hd items require class 4 or better. Stay above the minimum and you should be fine.
