IRDEATH
checking shim measurements and replacing as needed, reinstalled cam shafts per the service manual, everything is aligned cam chain on shafts 15 pins apart, above 3 on intake cam, above 2 on ex cam, reinstalled cam chain tension adjuster, everything is taught, but now when i use a socket wrench to turn cams by hand i only get maybe a half revolution and then i cant turn the cams anymore, i took cam shafts out, held cam shaft chain tight and used socket wrench and spun the chain around 3 or 4 times, put cams shafts back in and same thing happens again cant turn anything more then half a revolution, i used a little force the second time and just seems like the engine is locked up, any ideas, id like to be able to rotate the camshafts using the socket wrench before reassembling and starting the bike up. i turned the engine over about 7 times before i took the cam shafts out now that its back together cant turn more then half a revolution.......any ideas??????
