I went out to start the Bus and it was dead. Stone, cold, dead. Not a beep, not a peep.
I pulled off the seat and put a meter on the battery and it said .001 vdc. I put a meter on the Battery Tender and it said .000.
Puzzled, I put the meter on a small charger I use on the lawn tractor and 13 vdc. Hmmm. I put a 10 amp battery charger on the Bus, and in 5 minutes, it will turn over a couple of times. Hmmm.
I'm leaving the charger on for 30 minutes or so. I'll let you know what happens. But if the battery is OK (this is a 05 bike with 5,000 miles), then the Battery Tender must have crapped out and drained the battery at the same time.
After 15 minutes with the 10 amp charger, the bike started with the charger off of it.
Now the unclear part. I looked at the tender and it says if there is a blinking red light on, there is a bad connection. If memory serves, I did notice the red light blinking after I put the tender on after a ride. Now the red light is solid, and the green light is blinking. The tender is hot.
Really strange. At least it happened in the garage and not at some remote location.
