The bike ran perfect before the mods I did. I have a yoshi full system, TRE, BMC Race Filter, 16 tooth gearing, and a small box mod. I had a PC3 USB installed and the bike cut off at 9k rpms well I took it off and my bike goes till about 10k but sputters hard. I sprayed the inside of the injectors with carb cleaner and sitll same problem. I cleaned the Fuel Pump strainer I even bought seafoam and poured it in the tank still same thing.
Could it be a bad ECU?
Could an exhaust leak cause it I didnt use new gaskets when i installed the Yoshi System.
Could it be the injectors are shot and need replacing?
Also w hen I did my small box mod I used a dremel and I didnt have an air hose to blow everything out so I cleaned it best I could with a rag. Could that of maybe blocked something in the injectors?
Any help would be appreciated. My last test would be swapping out the ECU
