busa problems - Fuel filters,  ?
Someone please tell me where they are, looked in the manual and can't see them mentioned..........
1999-2000, inside the fuel pump assembly, located below the tank, right side, inside the foam. You have to remove the the pump assembly and take it apart to get to the filter.
I strongly suggest saving the $35 you'd spend on that OEM, POS paper filter and getting an in-line filter which will be much easier to change.
