Thanks for the help in advance.
Quick back story. 2000 Busa with 28K on it. I got it for the engine as I was going to put that in an Austin Mini I have. I have since done a bunch of things different and now will keep the busa as is. I did take it all apart to get the engine out and see about fitment. I have put it all back together now. I had the engine harness out, etc. It worked fine when it came out so I think I am missing something small.
I got a new battery as that was dead after 5 years of sitting.
I took a bunch of time to try to make sure the harness was in correctly with all the connectors connected, but you never know.
It turns over with the battery. I was thinking it was coil wires wrong, but they seem right and are labeled left to right 1-2-3-4. I pulled a coil and it does show spark.
It has good compression still as before.
So I have to think no fuel. I have fuel in. I hear the fuel pump running and it gurgled when I first started it purging the air so I am thinking that is working.
I did change the oil and when upright I can see the oil about halfway on the level window. Would not enough oil cause it to not run?
I did drop some gas in the TB with the air cleaner off and it did pop, but not run at all. I only did some fuel.
I jumped the connector to pull codes and no codes, but maybe it is because it is not running?
I checked the fuses and they seem good.
Thoughts on what could it be?
Thanks for the help.
Troy
Troy
