Kevin Jones
A bit more complicated than I thought and it took a while to diagnose the problem as I had a charging problem too. Unexpected and intermittent inability to idle and would only run at half throttle and like ass. I can post pics of plugs too if that tells any story but keep in mind my tuner fattened my low rpm and throttle % map too. Maybe not determinable by plug judging. Anyway, I had broken the special RCC check valve that goes between the map sensor and the throttle bodies. It took me a long time to find this out. It is a special check valve made to bleed boost off and not send an FI warning to the map sensor and it may be a little more than that depending on ecu settings (I think). I called Richard and it would take 2 weeks to get a new one from Canada. I called Rob and he told me go straight to map sensor and yes it would give the FI light. It did. It also didnt run right. It ran, but not well. You cannot simply place an autozone check valve inbetween the two. Face it the wrong way, it wont idle or run. Face it the other way, YMMV depending on your tune but you may not run well. So I googled. I found this. I made this contraption not using 3 check valves but 2. With 7 psi, I think I am ok. Sure there are 50 ways to skin a cat but this is seeming to work for me for now.
Qeustion on check valve to map sensor... - HomemadeTurbo - DIY Turbo Forum
