Brocks StreetMeg System
Busa_70461
I finally finished installing my exhaust system and PCIII today it was a piece of cake actually. It was as bad as some of the other post said. I Still have to put the fairings back on but I cranked it and it is a thing of beauty. I would like to thank Pipefighter248 for his videos because they hooked me. It sounds better in person. And thanks to bullettrain for his step by step pics.(they came in handy even though I had brocks). I am glad I found the Org. Thanks.
P.S. I will get out and ride tomorrow.
marble mod is where you put a marble in the rubber tube that goes to the bottom of your airbox. unhook hose from bottom of airbox tha goes to your pair valve and put a marble in it and hook back up to airbox. harmless all it does though is reduces back fire and flames out your pipe. all it eliminates is clean air going out with your exhaust which is just to make your exhaust cleaner but the fresh air makes backfire on heavy deceleration and flames on heavy exceleration. its a cheap alternative to pair valve mod
