Hey all:
Finally had time to install the Brembo Master Cylinder and the Pazzo Clutch Handle. I did the clutch handle first, since it was easiest first!!! Not much to it... remove the 10mm nut from the bottom of the pivot bolt. Then take a 8mm socket and ratchet and remove the bolt. Make sure you dont loose the bronze pivot for the clutch master rod. Clean everything up good... pivot, bronze pivot and the top and bottom of the clutch master assembly where the handle goes into. (The grease from the factory is dry and gritty.) Install the Pazzo clutch master cylinder back in the same order you took out. Just dont forget to great the pivot bolt, the bronze pivot, and the top and bottom paret of the new pazzo handle! It is much smoother to operate now, but hate that it hits the bar end on full pull of the clutch lever. Also #4 lever positon is close to hitting the dash on full lock... #5 and #6 setting will hit corner of the dash.
