Arkansas Brake's maybe? No really the noise is the pad "floating" in the calipers combined with the rotor runout. Remove and clean the pads and clean the brake dust with soap and water. Apply "Neverseize" lube to the end of the pad where it slides into the caliper and also to the mounting pins. Be sure to use it sparingly, a little Neverseize goes a long way. HTH Brian
