Brakes hanging up
bubbaloo
Hey all, having an issue with one front caliper hanging up and heating up the caliper. Pulled pads and cleaned things up. Just wondered if any of you have had the same problem?
IG.
What does it mean hanging up? Does it heat excessively from normal braking, or the brakes are dragging, i.e. it heats up without any braking? More details?
celticBandit
Did you clean the pots properly. Normally, with the pads off I would pump them until the pots came out a little. Be careful not to pump too much or the pots will come out and then you're screwed. Then use brake cleaner/WD40 to get rid of the ring of grime on the pots. Grease the pots up and push back in. You may need to remove the master cylinder cover and take out some fluid so that you can push the pots back in.
mike1180
Banned
When you pump them off the bike, you can put a piece of wood in between them that will stop them from popping out.
That will tell you if one of them is sticking.
You can also clean them with brake kleen and then rinse them with a spray of water, and wipe them off.
bubbaloo
Yeah I pumped each set of pistons out far enough to wipe the crud off them , sprayed everything with brake cleaner and blew them off with compressed air. I think they have been dragging for a while but noticed it when I put on the HH pads. One piston is a little harder to push in , I hope the seals are not cooked from the heat or it will be pull it apart and rebuild it time. Thanks guys.
kjcili
Actually, i've taken the calipers completely apart to clean them cuz I HAVE the same problem and if the pistons pop out, don't worry, they slide right back in. DO NOT ever use WD-40, or grease on calipers for any reason, those are petroleum based products and the oil will swell the seals....
warezdog
actually, i've taken the calipers completely apart to clean them cuz i have the same problem and if the pistons pop out, don't worry, they slide right back in. Do not ever use wd-40, or grease on calipers for any reason, those are petroleum based products and the oil will swell the seals....
+100!
Thread starter Similar threads Forum Replies Date
Dopey Finally have spongy front brakes Gen II Busa Information 5
mitchelldanger Why won't these Galfer Brake Pads fit back in the rear brakes? Parts and Modifications 35
SmokeKingOfCali99Hayabusa Rear brakes General Bike Related Topics 4
S Squishy Brakes General Bike Related Topics 9
Sandow Brakes, Oil and valves clearance check Maintenance and Do-It-Yourself 30
WuzzaCBXRider Whaddyathink of these brakes? General Bike Related Topics 12
SSGT_B Spongy Brakes General Bike Related Topics 74
T Fuel pump wont work when brakes are applied General Bike Related Topics 3
jellyrug K9 Stock brakes Gen II Busa Information 12
Kiwi Rider Brakes and the problems with fluid contamination . . Maintenance and Do-It-Yourself 11
F Click From Front Brakes Gen II Busa Information 14
N Front brakes wont stay bled and whats the best front stainless brake lines General Bike Related Topics 21
fast_pace77 05' ZX-10R front brakes on Gen 1? Busa Mods 4
GAmedic Brakes and other maintenance Maintenance and Do-It-Yourself 41
Tian Brakes Fading Busa problems 105
K New Busa Owner, need one bit of information about brakes General Bike Related Topics 12
busafan08 Front Brakes Again Gen II Busa Information 12
R New Busa, Reverting Front Brakes Back To Both Sides. General Bike Related Topics 6
S One Thread - Multiple Issues (front Brakes/idle/spark Plugs) Maintenance and Do-It-Yourself 30
13013 A Quest For Brakes General Bike Related Topics 38
c10 Brakes Gen II Busa Information 3
T I've Lots Of Go, But Need Wooh, Best Brakes ? Turbo 3
R Bleeding the front ABS Brembo brakes on my 2013 Hayabusa Busa problems 4
G New 03 Busa bought - advice for brakes New Owners Forum 11
K Brakes General Bike Related Topics 7
Sean298 dragging brakes Busa problems 8
I rear brakes replacement Maintenance and Do-It-Yourself 2
dadofthree Tires and Brakes Maintenance and Do-It-Yourself 38
fallenarch ABS vs Upgraded Brakes General Bike Related Topics 28
el stumpo bleeding Gen2 Brembo Brakes (ABS) Maintenance and Do-It-Yourself 22
mike04busa Gen 1 front brakes Busa Mods 16
F Bike doesn't roll after winter, front brakes stuck? Busa problems 13
isiahstites The Superbyke gets some new BREMBO BRAKES! General Bike Related Topics 13
Q perimeter brakes General Bike Related Topics 14
ogre retrofitting gen 2 ABS and brakes to a Gen 1 General Bike Related Topics 6
Jza Pre Brembo Gen 2 vs L3 brakes. Anyone ridden both? Tuffbusa need not reply Gen II Busa Information 41
Jza L3 brakes vs L1 brakes Gen II Busa Information 12
Ampz Both brakes or just front? General Bike Related Topics 5
hillbilly While looking for deals on brakes.... Maintenance and Do-It-Yourself 9
StrtRac3r Front brakes General Bike Related Topics 11
Audiomaker TCB Braking Systems? (anti-lock brakes) General Bike Related Topics 9
Rothman Why are Brembo brakes so much better? Busa Mods 6
P electrical issues with the turnsignals and brakes Busa problems 3
card16969 No front brakes tried just about everything i can think of Busa problems 26
T Front brakes sticking after steel braided line install........HELP PLEASE. Busa problems 9
HOOKDADDY ? brakes rusting Busa problems 8
B New B King owner looking for help with front brakes B-King General Discussion 7
H EBC Brakes General Bike Related Topics 3
M Why rear brakes only? General Bike Related Topics 82
omslaw Need to bleed your brakes? Harbor Freight Coupon... General Bike Related Topics 9
Similar threads
Latest Bikes
Forum statistics
Threads
174,603
Members
48,501
Latest member
Jamesds76
