. . . .. The last thing you want to do is push the pistons out of the caliper.
It's funny to hear that, every day at work I'm 'pushing trhe pistons out of the calipers . . . .
on farm quads.
They are so gummed up with poop and mud etc, the calipers have to be removed, stripped, the seals removed and cleaned with the seal recesses also cleaned out,
the slide pins freed up, cleaned and regreased, and the reassemble the calipers, fit them back on the mounts on the hub, flush new fluid thru the system, bleed the air out and test them. Every day, every quad, every 1000km service.
So for me to push pistons out, it's the quickest most efficient way of getting stuck pistons out of dirty old calipers.
But we are talking about pristine late model Busa calipers here in this thread,, and I know what you are saying when you it's the last thing . . .
A lot of people ride around on their beloved bike blissfully unaware that they have sticky semi-seized pistons in their brakes.
And it's almost always due to lack of servicing.
As soon as I get a new (to me) bike, regardless of the history that is conveyed to me by the vendor, I check the brakes , the fluid condition, the brake pad condition and what type of pads, the rotors condition etc, etc.
I then service them to as new condition.
But if you service your own brakes, as many here do, the fitting of new pads and fluid change with air bleeding is a cinch.
By the way, when pushing pistons back, try putting a hose on the bleed screw going to a bottle, open the bleed screw, clamp the (rubber) brake hose, and push the fluid out the bleed screw rather than pushing it up through the M/Cyl and into the reservoir. makes it easier to push the piston back too.
My 2c.
