Brake Light Not Working
Big Ron
I have a 05 Busa. I was doing my Buell foot peg mod today and noticed when I was going to adjust the rear brake as per the instructions I had no brake light working. The tail light works but no brake light even if I press the front brake.
The bulbs are still good. Any suggestions on what it could be. :please:
I need your help???
I need your help???
Check the fuse :whistle:
I bet the brake light is stuck on. The brake pedal switch has a spring that needs to be loosened to gain slack for a lowered brake pedal.
Thanks guys. I fixed it. I pulled on the brake light switch & adjusted it now it fine. :thumbsup: I should have messed around with ti a little more before posting. You guys rock. thanks for a quick response.
