Brake help please
Red baron
Guys got a bit of a problem that I didn't even see until now.
I'm building a gen 1 hayabusa quad with flat bars, but the two master cylinders sit slanted on the bars which renders them pretty much useless.(they fill half way and only just cover the piston) So ideally need something like the brembo rcs19 (think that was the code) or something from a different machine that has a separate resivoir, I'm also obviously getting bigger brakes and ideally wanted 4pots on the front, but apparently the gen 1 cylinders don't have enough fluid movement to be able to use 4pots,
So I guess if I have to change them then I might as well get some that will be able to use with 4 pots
AAny ideas would be greatly appreciated
#BestBrakeUpgrade ~ #BrakeHelp ~ #ImprovedBrakes ~ #THEoRg *
