Brake Kleen is the WORST thing you can use on rubber o-rings.......it will kill you're chain instantly. Anything thats hard on rubber keep away from an o-ring chainIs brake clean ok for the chain orings?
brake kleen is the worst thing you can use on rubber o-rings.......it will kill you're chain instantly. Anything thats hard on rubber keep away from an o-ring chain
I use kerosene and a rag and an old tooth brush.
Lots of people say that Brake Cleaner is hard on the o-rings. The O-rings in the chain are made of the same stuff that the rubber seals in a braking system on an automobile are made of, brake cleaner is mixed with this in mind and it does NOT affect the seals on a braking system and will not hurt the o-rings in a chain. Carb and choke cleaner is another story. I have on occasion used brake cleaner on a chain when it is off of the bike. Brake Cleaner is EXTREMELY rough on paint jobs and plastic surfaces.
I know I will get flamed for this but read the cans of brake cleaner and it will say it is safe for the seals on you brakes.
Flamed? You should be tared and feathered for even making such a statement!
does it work as well as brake clean? it just melted the grease and junk off.
Manual never says to use kerosineWelcome!
The manual says Kerosene only.
I wouldn't chance it.
Get a pump spray bottle from Home Depot and use the Kerosene.
It is cheaper than Brake Kleen too.
I understand. Personally I try to go with the bookManual or not - this is how you clean a chain!
