I've been lurking here for several months, since before I bought my 04 blk/prpl. I have made several mods based on reading this forum and have learned a bunch. I am currently waiting on my new HID setup, and have my .org shirt that I wear proudly.
I am in the process of installing Galfer SS lines on the front, along with some Carbone Lorraine pads. I decided to take my calipers apart to clean them as long as I have things torn down. I have not removed the pistons from the caliper, and the manual calls for the 4 o-rings at the brake fluid galley joints to be replaced. I called my dealer this morning, and it looks like the only way I can get the o-rings is to buy an entire "kit" that includes the o-rings, piston dust seals and piston seals at about $31 PER SIDE. I looked on Ron Ayers site, and they sell the same kit (pn 59300-33881 - for 26.82).
So here is my question - Do I REALLY have to replace these o-rings? I only have 5K miles on the bike, and they really don't look used at all. Failing that, is there some reason that I can't wander down to my local hardware store and get similar o-rings and use those? Are the Suzuki o-rings made of some special compound resistant to DOT 4 brake fluid?
I realize we are talking about some serious stuff here, braking and safety and continuing to breathe, and all that; not to mention the possibility of leaking DOT 4 all over my paint; but $25 to $30 a side is a tad excessive if I can get suitable replacements for a few cents each.
If I have to spend the bucks, I will; but I wanted to ask the question first.
I will be posting pics of my brake line install - routing lines, etc. as I get things put back together.
Thanks!
Thanks!
