Suzuki Squared
Hey everyone!
I see all this talk about 10-12psi being the max boost you should run on a turbo Gen 2 Busa engine. But no one is talking about this info for built engines??
I have a Gen 2 engine built with wossner rods and pistons, all upgraded hardware (valve springs, retainers, studs, bearings, etc...). With proper a turbo setup, how much boost will a setup like this be able to handle comfortably to make around 450hp? Not on low boost, but not too high either.
