Peter1127
Hi guys, new Hayabusa owner here. Bought a dismantled K2 with a failed rod bearing. It was a rolling chassis and 20boxes of parts. Good way to learn about your new bike:-) Got the manual and exploded views so not too bad. Needed to take some snapped off header bolts and pair studs out: fortunately the old “welding a nut on it” trick sorted that. Got a fresh crank&rods and put it all together. Bike started immediately, idled ok but after 5min of idling and blipping the throttle it started to smoke horrendously. Took the plugs out and cyl3 spits quite a bit of cooling fluid. Didnt know you could blow a head gasket at idle… Was a new gasket, torqued to spec. Cooling system was filled and vented and it didn’t overheat.
Gonna take the head off and have a look, curious about your thoughts.
