Which one, and will it fit into the Busa?hks makes an AWESOME piece.. i have one in my talon... also it is a dual diaphram system , so that under small amounts of boost it stays closed to improve throttle response , and is wiked sounding at higher levels of boost... ive tried about 7 different bov's and found the HKS to be the best....
Joe
NE: HOW does it connect to the plenum? Weld on the flange?Blow off valve H-RFL
Just connects to the Plenum and then vac line. Blow off improves performance if you look at being able to get back up to speed quicker. Neer had any problems with mine at all. Under the tank under a helmet still can hear the BOV.
Yes I have a stock Plenum polished.
YES, I do need one. How much??? I guess I need a flange also... or?the hks piece is the super-sequential, it is aluminum and is pretty light. from a "performance " standpoint the hks is MUCH better ! it doesn't blow off at low boost i.e. 1or 2 lbs, therefore when your cruising around you dont sacrifice throttle response between shifts as you would with the greddy part. btw that RFL valve is FREAKIN LOUD! BUT the performance issue comes into play again with the throttle response. i keep the hks piece in stock if you need one.
JP
Use a Tial with a 9pd spring. Can be bought for under $200 off the net. Besure to order it with the aluminum flange so that it can be welded to your plenum.YES, I do need one. How much??? I guess I need a flange also... or?the hks piece is the super-sequential, it is aluminum and is pretty light. from a "performance " standpoint the hks is MUCH better ! it doesn't blow off at low boost i.e. 1or 2 lbs, therefore when your cruising around you dont sacrifice throttle response between shifts as you would with the greddy part. btw that RFL valve is FREAKIN LOUD! BUT the performance issue comes into play again with the throttle response. i keep the hks piece in stock if you need one.
JP
Thanks
From what I heard from Scott, it will help with traditional shifting as it keeps the boost high... with an air or electric shifter, it probably won't matter much since it stays in boost the entire shift...Will a BOV be of any help when strickly drag racing? I let off the throttle kida slow after crossing the finish line to let the boost drop off slower, I dont know enough about the BOV To know if it would benifit my aplication.
