Blinkers blinking too fast. Please help!!!!
Shilpan
Hi! I put after market undertail with integrated turn signals. It has LEDs. Due to this my blinkers blink too fast and I can not pass inspection due to this. Any suggestion??? Someone told me to put a resister in it but I wanna know what kind of resistor and where do I put it?
heavybusa
Just another guy
A search will find the answer... I know I've seen this posted before.
mike04busa
Look at rumble imports web site, they have one for around 16$. If you search like said before there is enough on this topic to help. very easy to install.There may be ones cheaper or one of the site sponsors could help also.
Shilpan
Thanks heavybusa, first thread seems to have all the info.
Leo
Put your stocker back in for inspection
Then use the faster rate, that's what i did, and I find it gets peoples attention better than a slower rate...
heavybusa
Just another guy
Thats straight from a Leo.
ibified
Radio shack is your friend. get two of the 10 ohm/10 watt resistors and wire them inline on your LED lights. problem solved. and your total cost will be about 5 bucks or less.
Shilpan
inline connection means? resistor has two ends so should i connect on end to positive and other to negative or just cut positive to my blinker and connect it to two ends of resistor?
Vic_E55_2001
just like another bulb, one end to negative another to positive.
Johnnycheese
(ibified @ May 24 2007,15:18) Radio shack is your friend.  get two of the 10 ohm/10 watt resistors and wire them inline on your LED lights. problem solved. and your total cost will be about 5 bucks or less.
pepboys 12vt turnsignal flasher 1.99 even cheaper
dadofthree
Seasoned Beef
(ibified @ May 24 2007,16:18) Radio shack is your friend. get two of the 10 ohm/10 watt resistors and wire them inline on your LED lights. problem solved. and your total cost will be about 5 bucks or less.
10 watt
I would recommend contacting the manufacturer.
