http://www.geocities.com/changeyourblinkerfluid/blinkerfluid1.html
http://www.kalecoauto.com/fluids.htm
http://autorepair.about.com/cs/funstuff/a/aa040101a.htm
mlarson2k3: want to get that done before i ride it again...
gb: dont forget to test and/or switch out the blinker fluid and extake choke
mlarson2k3: blinker fluid xtake choke?
gb: doesn't Kawasaki taek special blinker fluid? you need to look it up online and see teh procedure for that
mlarson2k3: what the hell?
gb: look it up
gb: find it?
mlarson2k3: google shows nothing...
gb: huh? i got tons
mlarson2k3: give me the search you are using url google?
gb: Blinker Fluid
mlarson2k3: blinker fluid kawasaki gives me nothing...
gb: oh, I just figured KAWs had some info somewhere
mlarson2k3: my blinker are fine...
gb: oh okay. might work for about 10k miles or something. Suzuki uses the air system instead of blinker fluid for inductive purposes
mlarson2k3: I don't remember seeing anything in the recommended maintence for blink fluid but I will check
gb: okay. mayeb on your next oil change you should just ask the mechanic to taek care of it. it should be quick and easy and they stock the stuff so they wont charge you for an ouce or whatever
mlarson2k3: screw that they charge too much
gb: well, you can do it easily, jsut gotta find out how and where to buy it
gb: look it up
gb: find it?
gb: huh? i got tons
gb: Blinker Fluid
