schmud0811
ok i installed a new exhaust changed out the body work for some fiberglass from catalaist and took off the evaporator canistor ,its a cali nodel...the bike started before but now will not start shows code c00 no error everything is hooked up correct as i can see the kickstand sensor is fine i am clueless to the problem sounds like the fuel pump is working fine...she turns over but will not start any help would be apreciated thanx,oh my fan also doesn't come on when its supposed to anymore either the fuze is fine and the fan engine works fine also i checked it with a 12vt sourse....things are getting confusing.........
