There really ain't no best way...It will take both of you because the area is so tight...One hold the tank up while the other disconnects the lines...If you have a small bolt you can place that in the line opening to prevent wasting alot of fuel every where...You'll also need a set of needle nose pliers the longer the better to loosen the fittings...Good luck pain in the a$$...
just make sure your low on gas.... a full tank is very heavy...
just ask my zx-11 friend; the poor slob had just went to the gas station the day before he planned on changing the plugs!
