Battery tender
BK24
Those using it, where do you have the plug routed? I zip tied mine under the hump so it is easily accessable by removing the hump/pass seat. Anyone have it mounted in a better place requiring no removal of anything?
thepushercg
veni vidi vici
unless you want to run it out the front around the horn you picked a good spot.
BigBSBusa
Maybe I'm missing the point of this thread! I remove my front sit and connect it up.
MoosesBusa
Former BusaHolic
I permanantly atached the connectors to the battery. I then routed the Tender plug in down the right side of the bike directly below the rear of the front seat and wire tied it to the rear brake hosing by the resevoir at the front of the swingarm. easy access no muss no fuss 5 minute install.
BK24
(BigBSBusa @ Sep. 30 2006,20:14)
Its connected to the battery. ;)
I'm refering to where others have the plugin routed to for hooking the charger up to.
BK24
(MoosesBusa @ Sep. 30 2006,21:11)
I thought about hooking it to the brake housing but thought it may be an issue with tugging over time.
GSXcite
Squirrel Master
I know this post is a few days old, but I have my wires routed down to the space on the left side below the hump where the grab bar is to help lift the bike on a center stand. If you look at the space on the right side it is not open and has a black cover on it. On the left side there is a small lip that will allow you to fold the wire over and tuck it out of sight. To hook up your charger, reach in and pull it out, no seat to unbolt.
heavybusa
Just another guy
Mine runs behind the brake resevior tucked behing the rear set.
drumminman
(BK24 @ Sep. 30 2006,15:46) Those using it, where do you have the plug routed? I zip tied mine under the hump so it is easily accessable by removing the hump/pass seat. Anyone have it mounted in a better place requiring no removal of anything?
+1 I've got mine routed in the same place. It works and is easily accessible.
ONE MORE BUSA
(GSXcite @ Oct. 12 2006,18:51) I know this post is a few days old, but I have my wires routed down to the space on the left side below the hump where the grab bar is to help lift the bike on a center stand. If you look at the space on the right side it is not open and has a black cover on it. On the left side there is a small lip that will allow you to fold the wire over and tuck it out of sight. To hook up your charger, reach in and pull it out, no seat to unbolt.
+1
I put longer wires on mine and have the plug in the same place
