Buy Now: Motorcycle Bike Tools | Pashnit Moto
One just has a few more features.
Battery Tender Junior
*Fully automatic two-stage lead-acid battery charger
*Trickle Charger assures batteries are maintained after charging gel cell batteries
*On 12V models, after full 14.4VDC charger is reached, converts to float charger and monitors battery at 13.2V; when voltage drops below 12.6VDC, charger resumes charging back to 14.4VDC
*Two-color LED indicator
*Spark-proof; reverse polarity protected
*12' output cord and quick-connect harness
Battery Tender Plus
Comes with:
*Constantly monitors the battery without the damaging effects of trickle chargers
*Voltage output compensates for temperature changes
*Initial charge brings battery to full charge at approximately 14.2V
*After full charge is reached, converts to float charger and monitors the battery at 13.2V
*Although a constant charge is being applied to the battery, there is little or no current (approx 10mA)
*12V Battery Tender Plus has new fused quick-connect rings with a weather cover
Also got one of the Yuasa's in stock too:
Yuasa SmartShot Battery Charger
1.5 Amp - 6/12 Volt Charger/Maintainer
Model 12V1500
For a real powerhouse charger YUASA’s 1.5 amp SmartShot features five-stage charge circuitry that’ll bring a completely discharged and partially sulfated battery back to life. SmartShot’s 28-day charge recycle circuit automatically re-evaluates the battery’s status when it’s set on the shelf for long-term storage.
*Has the ability to charge both 6V and 12V batteries
*3 LED indicator display
*Spark-free operation
*Switches automatically to float mode, built in timer for battery protection
*28-day charge recycle re-evaluates battery condition for long-term storage
*Provides up to 16V for recovery of sulfated batteries
*Reverse polarity protected
*Easy, error-proof operation; designed to prevent overcharging
*Charger ring connector available separately
*Output 6/12VDC @ 1.5 ADC
*Input 120 VAC @ 60Hz
