V-Max 2 Busa
Set out for a nice 500-600 mile solo ride today and after approx 100 miles I pull over to fuel up and after fueling she won't start. The most I could get is a rapid clicking noise coming from the starter I believe. I managed to push start her but I seriously do not recommend doing this with a Busa especially in full gear and Sidi boots, damn near droped her once. Anyhow I jump back on the freeway and make a mad dash for home with only 100 miles to go. About every 20 miles or so all the gauges start bouncing, all the instrument lights start going on and off and the bike is surging on and off as I'm droping gears gradually losing speed hoping she'll start running smooth once again. Down to 2nd gear I pull in the clutch and turn off the power switch for a few seconds while coasting on the shoulder, flip the power back on, pop the clutch and quickly accelerate back up to cruising speed. She repeats this approx every 20 miles or so. Thank God I did make it back home and she sat there idling like nothing was wrong, shut her off and tried to restart only to get the rapid clikcing noise again. Checked the voltage which registered 12.5 volts with the key off, turning the key on the meter drpoped to 8.5 volts. Is my Battery toast or is there something else going on here?
