99 Busapilot
I've just completed a complete front and rear brake rebuild of my 99 Busa. New pistons, piston seals, and Galfer brake lines.
The rear brake took 10 minutes to fully charge and bleed.
I worked on the fronts for over an hour and they aren't even charged yet - no action from brake lever.
I am thinking that the rear was easy since it is only two piston. However, on the front I have a total of 12 pistons (each of which were completely empty with the pistons fully disengaged at time of reassembly) and new individual brake lines which were empty at time of assembly. I also imagine I am pumping so little fluid through the lines with each lever pump that it'll take til fall to get the lines charged so I can bleed the air out.
I found this: http://www.wardsweb.org/busa/hayabusa_bleed.html
Any help?
Any help?
