Getting this Ultra plenum to fit on the B-king. Had to eliminate the ignition cylinder and lock, then cut the composite bracket that holds that and the tank hold down bracket.
Just need to do some cutting on the composite part of the tank bracket tomorrow and then everything should line up.
Will have to close off the inlet to the plenum and place a new inlet into the center part of the plenum, then find a place for a blow off valve.
Engine is built, just waiting on my NLR boost clutch to show up. Pictures will post as I make progres..
@faseljd
@Boosted Cycle Perf
You guys might like to watch this.
@faseljd
@Boosted Cycle Perf
